Car Not Used Over 4 Months
Hi guys/gals,
Just need some advise. My dad has an old Merc (12 yrs old, but done like 24k) and he hardly ever drives it. Hes been away on holiday and not be expected back for another 3 months or so (the bliss of retirement lol). When i went to check if the car is ok i noticed that the front offside has gone flat, from lack of use. Will probably need new tires as its flatten it. So is it good idea to jack it up and place bricks underneath the car (either jacking points or axels) so to take the pressure off the 4 wheels/tires?
cheers.
Always worth jacking it onto supports if you are going to leave it that long. That's if you can't get to it regularly and rotate the wheels a bit. It's gone flat because it has a leak somewhere ... otherwise all four would have gone flat.
