Ls 400 Transponder In Key
lobes
I have a 99 LS 400, the only key I have for this is the 3 button master, all keys have a transponder fitted, i tried to buy a new key in Australia 7000 km away. i was told the only way they could make the transponder work on a new key was if they had the car as well as the master key. the Car is in New Guinea and there is no Lexus dealer. [the Toyota dealer asked' what is a Lexus'] can anyone help? Is there any way the transponder in new keys can be programmed without the car?
Lobes
Lobes
I bought a secondhand key and a new blank key off eBay. I got the new key cut and put the transponder from the secondhand key in it. Then I programed the key to work in my car (this is done inside the car), got all the info from google.
Andrew
  • 2 months later...
I think This is the link I used, I had to program the key and the remote.
Andrew
Re programming transponder key to work
Thanks very much for your info, it took me 2 months to get spare keys, it is not easy when you live on a tropical island, used the info from the website ie push accelerator 5x, push brake 6 times etc and miracle it worked. cannot thank you enough for this, I can now relax knowing if I lose the key I wont have to ship the car 5000 miles.
I also found that programmable keys are available [not from Lexus], if you have a master key you read the data from the transponder and then program the transponder in the new key to match. only drawback cost of about US$250.00 per key
thanks again LOBES
