Brake Caliper Servicing
Steviewevie
do one caliper at a time also clamp off the flexi once you have removed the pistons
How would you do that if you have stainless brake lines ? Just curious, I haven't fitted mine yet but really must get that organised !
If you want to remove the caliper and you don't want to/cannot use the clamp method, you must hold the brakepedal down by blocking it with a stick between the driverseat and the pedal. This way the holes between the mastercylinder and the brakefluid reservoir will be closed and no fluid comes out of the brakelines and no air can get in the system. Now you can remove the brakeline from the caliper and no fluid comes out.
