Engine Roughness After Oil Pump Went
lexyman
Hi i recently had my oil pump go on me. On the way to the garage the engin management light and everything came on and the car stopped. The oil pump was changed and the car seemed to run fine but i did notice a very slight rough ness as though the timing was out. I took it to another garage and it was plugged into various gizmo athat said the timing was out but everything else was spot on. the timing belt had been changed but still there is a slight roughness. Nothing is being picked up on any computer. Everything is saying the engine is ok and sure enough it runs fine. but there is a very low level roughness that you can feel through the gear stick. and hear if you tweak the revs at low tic over.
I have been told it may be the "balancer shaft" is this a possibility. Any pointers appreciated - thanks
Ha Ha...mine is on the motorway a lot and does get pushed hard and i love it. So if you’re in the Midlands and see a silver one up your arse it’s probably me ...lol. Yes because i drive shall we say at the high end it gets serviced very regularly.
