Wheel Alingment Help Needed!
lexus2000
Try:
My controls
Options
Manage your attachments
cheers mate cant get it to work ill put up my settings
front axle
total toe +00.12
camber +00.37
caster -00.55
king pin angle -01.94
rear axle
total toe +00.26
camber +00.29
thrust angle +00.01 can anyone help please
Try:
My controls
Options
front axle
total toe +00.12
camber +00.37
caster -00.55
rear axle
total toe +00.26
camber +00.29
Those figures cannot be right..... pm me your contact number and i'll call.
Try:
My controls
Options
front axle
total toe +00.12
camber +00.37
caster -00.55
rear axle
total toe +00.26
camber +00.29
i think ive put them up right if you give me your email address il forward it to you to take a look at it thanks
Try:
My controls
Options
front axle
total toe +00.12
camber +00.37
caster -00.55
rear axle
total toe +00.26
camber +00.29
tony@wheels-inmotion.co.uk
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
