Radio Questio
Error3 on display. can you get a 2nd hand radio and will it work.
radio started working again for a few days but gone again
i know where there is 3 is200's getting scrapped.
just asking because of sticker on the drivers window when radio is removed itm wont work.
2nd hand units will work as long as you get the right one. You need to make sure the replacement unit has the right code.
There should be a number on the front of your headunit (eg: 13903). The replacement unit must have the same number on the front otherwise it won't work- they have different connections. So if you have a 13903 unit then the 2nd hand one must have the same number on the front.
