Help! Sunroof
hi there, please can someone help me i have a 1999 is200 my sunroof is in-op i have no power at the switches or at the motor checked fuse thats all fine and checked for power there and its fine but on the roof there is none! i would like to get this sorted for the summer so really need your help is there a way i can run a new fused live up if so which ones need to be live and earth. any help would be grateful
many thanks matt
yes through the sunroof ecu to the motor but not through the switches. you'll find that a lot most things are earthed to send a signal to an electronic unit. Its also safer incase of bared switches or something.
