Knocking Noise Front Suspension
keith 1
hi it turned out i had a similar problem on my is sport i changed the track rod ends and still had knocking turned out it was my brake caliper. The caliper slide seels had gone causing the rattle also the brahe pad springs were missing on one side.The way to identify the problem is find a rough road and travel about 30-40mph and brake to a gentle stop as you go over the rough in the road while braking the rattle should stop, if it does its your calipers if not cant help ye hope this helps good luck
