Is200 Clutch
my is200 starting with a clutch click which was play in the top of the pedal where the pin and r clip sit so ive added a washer to stop the sideways movement thats great now. but now ive noticed a creak when i depress the pedal which is coming from the gearbox. and also my release bearing is now squeaking until i lightly rest my foot on the pedal. and its really annoying can be heard inside and outside the car.
my guess is i need a new bearing. for now i have adjusted the stop at the top of the pedal so the pedal doesnt return as far as it did and so giving the same effect as me resting my foot slightly on the pedal. and the noise is gone. will this cause any problems.
and if i get a new bearing and clutch will i need anything else. the arm the bearing slides on maybe. as it seems this drys out??? or will this be ok.
thanks scott
