Please Help A Newbie:)
Darren- 1980
Hi i have only had my is200 a few days now and the pass side spring has snapped, took it to a garage and they said the shock is no good either and the drivers side spring and shock could also do with replacing
I found someone breaking a low mileage car on eBay and have got 2 x rear springs and shocks on there way so i thought id get started and remove the old shocks... here comes the problem lol
While removing the shocks using this very helpfull guide i found on this site ( see us newbies can use the search button :P )
http://www.lexusownersclub.co.uk/knowledge/index.php?page=index_v2&id=55&c=5
I managed to shear both the bolts that hold the strut to the inner arch pictured below (not my pic but one from above tutorial)
how important are these can they be left off :question:
if not and they need to be there for safety how do i go about removing the thread thats left in the inner arch as all i have left of the bolt is the heads that snapped off :whistling:
many thanks for any help
Darren
Welcome to LOC, usually if there is a bolt there it's for a reason. That one looks like it holds that housing to the chassis - so yes you need it there. You can drill it out and see if you can then remove it or turn it or buy lend en extractor which would drill in and allow you to turn it.
