Neutral Safety Switch Replacement
LS400ANTH
Hi Guys,
I need to replace the neutral safety switch this weekend on my LS400. (1995)
Does anyone have a few pointers on doing this....for example anything which needs removing first or tips on how to do it
Anything would be appreciated
Best regards
Anthony
Hi Guys,
Best regards
Anthony
This is for '94 series two.
Before you replace the switch check this:
loosen the neutral start switch bolt and set the shift lever to to the N position
There is a line on the cover
Align the groove and the line and then tighten the bolt
the groove is on the lower hexagonal below the fixing bolt, tighten 9ft.llb[13 n.m]
This is the basic neutral switch setting
I think you may have to remove part of the exhaust to replace the switch
Hi Guys,
Best regards
Anthony
Great thanks for this. I will look into it at the weekend and advise!
Ant
