Warning Light On Help
I would physically check if the throttle butterfly is completely closed when the engine should be at idle, if you have an ODDII code reader see what the stored codes are.
Could be a stuck throttle,TPS, vacuum leak or a few more causes besides, you really need a diagnostic code(s) pull to point you in the right direction.
