Cracking Noise In Dash & Heater Fan Is Poor
Hi everyone new to the site and grateful for any help
Haven driven an IS200 Sport for 8 years without any issues i have since upgraded and bought an IS220 SE 2006 77000 miles.
From the offset i have noticed that it takes an age for the car heaters to warm up, with the Fan at full speed it barely clears the windows until you are well into a long journey.
periodically i get a loud cracking noise which sounds like a large stone hitting the window from the dash area.
The MPG isnt very impressive with under 40 cruising on a motorway
any ideas ??
any ideas ??
You may want to check your head gasket as there may be an issue here. Check these links for some info. In the meantime take a look at your radiator top up bottle water and also inside the neck of the oil filler cap. Good indicators of Head Gasket problems.
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=70967
and here
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=70826
The crack sound is a known issue which can and should be remedied by Lexus {it's damned irritating isn't it?]. Check here
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=71783
Try using the heated windscreen button. It will intensify the air flow to the screen and clear it in less than a minute. Its down under the steering wheel on the right hand side
any ideas ??
For issues on MPG take a read here
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=71274
The loud cracking noise is a safety feature - just when you are dropping off, it scares the daylights out of you! The first time it happened to me, I was convinced that a stone had hit the windscreen!
