Can You Turn The Vsc Off
is300kris
Hi there!
it is possible. You need to put switch on steering angle sensor power wire.
when car is started, push that switch, VSC system detects fault and will turn off. So as Traction control. ABS will work as usual. VSC will reset next time when car is turned on.
look in american forums
http://my.is/forums/f88/vsc-disable-344712/
