Headlight Advice
most hid kits are the same......but there are some really chep nasty stuff on eBay so just be aware of what your buying.
You should be well able to fit the kit your self as it's all plug and play...the only difficult bit is mounting the ballast's
O and be warned to keep a few fuses just incase you connect the plug from car loom to the ballast as it could be in the wrong way round and just pop the fuse under the bonnet fuse box
