Is200 Whiring Noise From Rear
coopa
I have recently noticed a whiring/humming noise from what I can gather drivers rear. I think it possibly the wheel bearing. Just wondered if any else has had this. If it is the bearing how hard is it to do or do I need any specialist equipment. Ie does it need pressing on
hi ive just been looking into replacing mine after it being a advisory. Looks like a tricky job, you will need a bench press or a puller tool at least and a big socket, tools i just dont have. so im taking mine in. Will prob buy the parts myself, seen them go for around £50 each, not sure how much a garage would charge because my friend always does work for me at a discount.
Its a sealed bearing very similar to this i believe, (not the hub type although replacing the whole assembly is possible)
