How To Tighten Power Steering Belt?
hi, im no mechanic but i certainly love to diy when i can..
i have been searching for hours now and cant seem to find a detailed description of how to tighten the power steering belt on my is.... its a 2002 se auto.
i did a full atf flush on sunday hoping that the screeching noise and stiff steering issue would go, but whilst doing that i discovered that the belt keeps spinning and the pulley stops. i imagine my belt is loose?
any pics / tips / advice on how to tighten the power steering belt please anyone?
Did this the other day on mine, 14mm spanner and a pry bar required. There is an adjuster near the alternator slacken it off and use the pry bar to put tension on the belt, hold the tension on and tighten adjuster.
Hope this helps.
