Antifreeze Top Up - Is200 2004
Quick questions(s) for all your knowledgeable folks.
Noticed my antifreeze level is right at the bottom of the antifreeze reservoir.
1. How much do I need to put the level between the min and max levels?
2. Would you use just distilled water.
Top it up with pink/red antifreeze,just make sure you don't top up above the maximum level line,by using just distilled water you will be diluting the strength of whatever antifreeze you have in your system.
