Number Plate Bulbs
snubz
iknow there are probly plent of post on this post but most links to the bulbs do no work or has been removed.
can anyone tell me if these are the correct ones? I am after some bright white ones, if not can someone post the correct ones? cheers.
http://www.ebay.co.uk/itm/10x-ERROR-FREE-CANBUS-T10-5050-5-SMD-LED-XENON-HID-WHITE-W5W-501-SIDE-LIGHT-BULB-/301396280616?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item462c9e4528
  • 6 months later...
It's a stupid design, which makes replacement a PITA- which is why I do not recommend fitting cheap LED replacements, as they typically don't last as long as regular bulbs, so you'll need to change them more often
