Electric Windows
The Battery on my GS300 went flat due to side/parking lights being left on inadvertently over a period of 3 days.
This has resulted in the blocking of the electric window operation on all but the driver's window.
I understand that this requires a "re-set" to re-enable the passenger and rear windows to operate.
Does anybody know the process of performing this "re-set" ?
Peter
This is my "How to" from the 250 section
May well work on yours too
When you change the Battery you MUST re-initialize each window in order to be able to control each from the drivers door switches.
In order to do this you perform this operation at each window using the switch on the door for the window you are at. If you look closely at the small LED on each switch you will se it is blinking - this indicates the windows need initializing.
1. Open the window halfway using the door switch.
2. Fully close the window by pulling the switch and continue to hold the switch up for 4 seconds or so.
3. Do this at each door.
When complete the blinking will change to being a constant glow ie 'on'.
Your windows will now fully function again from the driver's door control set.
Hope it works
