IS200 Sat Nav
Mars
So I turned my Sat Nav unit on this morning and it was a bit slow to open/respond but it did open and I was met with a message "Unable to read data. Check map dvd is correct."
Any ideas as to what is causing this?
Perfectly for the past 14 years. Changed the interior during the summer and everything electrical was working fine thereafter. The one thing I have noticed is the there is condensation on the insides of the front and rear screens.
19 hours ago, scudney said:
you might have to take the disc out and give it a clean and see what happens
Ok so the DVD Disc is out. Looks fine and the system is detecting that there is no DVD in the reader. Going to clean it up and see what happens.
2 hours ago, scudney said:
glad to be of assistance,giving it a clean usually works if there's nothing wrong with it,haven't had any problems with mine 😊
Personally I think it may have something to do with the weather.
