fog lights and cd changer
are you looking for the front fogs or the rear?
The front fogs should be situated on the same stork as the indicator stork. Twist for normal light switch then further down the stork you should find another twist switch.
I am going by what i have on my ES300... but most have the same equipment.
I've a sony 10 disc changer that I'd sell for £90. I'd only had it a few months before I removed it from my Vauxhall - cost me £180 new. Only thing is I guess you'd need a sony head unit with cd changer controls to make use of it.
The fog lights r for the front of a 92 sc300 the stork does not appear to twist anymore. Seems kind of weird that i cannot locate it anywhere. I pressed all the buttons yet it still doesnt work.
For the cd changer i need a factory 1 since the radio unit is connected to my air conditioner so i cant use a aftermarket because i dont have the wires
thxs for ur tym
hmmm... should be on the stork... most toyotas are the same as Lexus too... all use the same types of stork.
By the way.. you have to have your main lights on for the fogs to work (when you find that switch)
