Heater Problems
Rishi
Hi guys, wonder if someone can help me? My GS300, 2001 plate, is blowing out cold air on the passenger side, whilst the driver side is hot. To assist, a bit of a background - the car was recently diagnosed as having head gasket problems. Having researched the internet, I found this so called elixir - "steal seal", which was guaranteed to seal all head gasket problems or your money back guarantee. Weighing up two bottles of this stuff for £60 against £1000, I took the gamble. Unfortunately it did not work, so I ended up having a new head gasket and a new radiator as it was all clogged up with this cement like stuff.Following the head gasket change, there was no heat coming out from the heater. After flushing the heater matrix several times, eventually managed to get very warm air. Even when set at the max temp of 30, whilst the driver side is just ok - not brilliant as it was previously, however, the passenger side is blowing out cold air. Any help would be greatly appreciated.
Many Thanks
Rishi
