Air Pump For Brake System Issue....
Hi guys
Need a bit of advice about this issue, when you first get in an RX400h there is a pump that runs under the bonnet that pressures up the power assisted brakes, this pump and small compressed air tank is right in the far left hand corner of the engine bay under the plastic cover, basically right behind the Battery.
It sounds like i have a small air leak from this or the pipework close to it and this is making the pump run more than normal to pressure up the tank ?
Anybody had this issue ? Or know where this small leak is possibly coming from ?
The brakes are still functioning perfect.
Thanks in advance
John
