Is300 Ambient Air Temperature Sensor
Hi...have located it. On my is300h the ambient air temperature sensor is located immediately under the upper horizontal frame of the 'chickenware' on the passenger side, below the front grille, as per the attached jpg. You'll see the sensor part is a 'stub' shape. You can reach it with a small pencil sized cleaner and water squirt bottle. It did not seem to be that dirty, but hopefully the clean has improved its sensitivity/accuracy
Hope that helps!
post-48557-0-49635200-1452817649_thumb.j
Hope that helps!
Well done! Will be of help to someone.
