Hello,
First off I don't really post much on here, but this site has helped me out a lot in the past when it comes to little niggles with the car.
Unfortunately this is one where I can't really find an answer... and it's about the steering wheel squeak, creak, rubbing noise.
Now I have taken a small video so that you can hear it. Apologies for the camera moving around as I tried to show where abouts the noise is coming from.
https://www.dropbox.com/s/as30zo7e8yj35lr/IMG_1600.m4v?dl=0
I am pretty sure the noise is from the drivers side.
At a guess I am assuming because the steering column is obviously on the right.
It's an IS200 that has done 155,000 miles if that helps.
I did read that I should spray WD40 where the steering column comes through the footwell.
This sort of worked, but to be honest as there was no pics, I sprayed half a can where ever I saw something that looked like a join that could squeak.
Does anyone know what it is and how I can fix it?
Thanks for your help.
