I'm considering replacing my IS200 with a GS300. I'm specifically looking for an SE model with Sat Nav, probably upto a 2000 year model.
What should i be looking out for - are there any known problems that i need to be aware of?
Thanks,
Sandeep
Cheers guys.
Colin - what were the main changes to the post Nov 2000 models. Were there mechanical changes, costmetic changes or a combination of both? Of the ones i have seen, I have noticed the Sat Nav unit on the newer models looks slightly different.
I think these are most of the changes:
DVD sat nav option not CD based which also has a widescreen not 4/3 display.
Different stereo, although seems the same quality as the older one
Brake assist
Electronic Brake force Distribution
Larger brake master cylinder
Curtain airbags
Double locking doors
Seat belt pre-tensioners
E-SHIFT
ISO-FIX child seat fixings in the rear seat
Chrome trim around gear selector
Trim around dashboard dials is much better looking
Steering wheel has chrome L badge
Front ashtray is now in wood effect rather than grey plastic
New rear light cluster design
Slightly different front light design
Service interval is 10k miles not 9k. Cam belt change at 100k not 63k
suspension was also modifed to give better ride altough I'm not sure if this was with the facelift or the year before.
