Hi Roy,
                      I changed mine yesterday. There is a section at the back of the glovebox you pull out then you'll see a white plastic cover behind that with two tabs at the bottom. Unclip that and pull the filter housing down and slide out. The filter sits in a plastic housing which needs to be pushed up once slid back in to allow the white cover to close.
Hope that helps.
Dunc
