P0017 - recommendation on where to get a timing chain kit?
Xane
Lexus GS450H just got the P0017 fault code. I am LED to believe this means a stretched timing chain. I am yet to check for the minor things like sensors.
A timing chain kit from Lexus is quite expensive (including tensioners and gaskets).
Any recommendations on where I can get a cheaper, OEM quality timing chain kit?
Thank you
Thank you for this. I have just recently discovered Rockauto. The prices seem to good to be true!
The problem I am having is that I do not know all of the part numbers. I need a full kit including the gaskets.
Does anyone know the part numbers?
I don't think it has one - not according to this parts catalogue:
https://lexus.7zap.com/en/eu/lexus+gs/334510/gws191r-bexqhw/1/1106/114126a/#11328
and the repair manual for a 2012 GS450h (same engine) shows the use of a sealant rather than gasket at step 40:
http://zatonevkredit(blocked word)/repair_manuals/raw_content/AWIxsx8YU9h2CeTmchFc
