M600S entertainment unit
Likely purchasing one of these from another forum member.
https://m.aliexpress.com/item/1005002695883691.html?gatewayAdapt=Pc2Msite&spm=a2g0o.9042311.0.0.7a2e4c4dnfRxP4&utm_source=LexusOwnersClubUK&utm_medium=ForumLinks
got an 08 IS250 SR with standard radio unit. Has anybody on here installed one on a similar car?
If so, is it easy to do, reviews, pros & cons etc etc.
If it has correct wiring harness for your model, then it will be plug an play - very easy.
If not then it will require very capable electrician to figure out what should go where and modify the harness - so very very difficult.
