Rear output flange for a A650 transmission
MGBV8SWAP
Hi guys, I need your help. Does anyone of you knows a regular output flange for the a650? Maybe a flange which is interchangeable from another toyota model? I'm not talking about the flange for the rubber disc! I want to use a normal propshaft without center support bearing! I'm doing a 1uzfe vvti swap to a MGB. Thank you so much!
