RETURNING FROM HOLIDAY I FOUND THAT I COULD NOT OPEN MY CAR THE ELECTRONIC KEY IS IN WORKING ORDER THE MANUAL ADVISES ME TO USE THE MANUAL KEY WHICH WAS UNABLE TO FIT IN TO THE LOCK THE MANUAL ADVISES THAT IF THIS HAPPENS TO USE THE OTHER SIDE OF THE KEY TO REMOVE THE LOCK COVER BUT THE FIT MENT ON THE KEY WILL NOT LET ME DO THIS CAN ANY ONE GIVE ME ADVICE AS TO WHAT I CAN DO TO RESOLVE THIS SITUATION
There is a hole at the bottom of the lock cover, it is exactly the same size as the key and you just need to pry it open. However I advise have some tape on the key or use plastic trim removal tool instead, because otherwise you may scratch the paint. The next thing you need to consider is whenever the key Battery is flat or the car Battery is flat, if it is key, then you can touch the key against the start button, but is later then you need to charge or replace the Battery.
