Blower fan noise (RCF)
Has anyone taken out the blower motor/fan on an RC/RCF? Just want to get an idea of difficulty before I take it to Lexus.
Mine started making an annoying noise last week. Sounded like something caught in the fan at first, now turned into a pretty nasty squeaky kind of noise that's present constantly unless I turn the climate control fully off.
Not too thrilled that I'm already dealing with my second gremlin with the car, but maybe it will be an easy fix...
  • 1 year later...
On 3/17/2024 at 8:15 PM, TomLC500h said:
My LC has a noisy blower fan too
I got mine fixed in the end and it was apparently just a leaf stuck in the fan housing. Lexus Guildford didn't even charge labour so I can't imagine it was too much work for them to get out.
Every time you remove the filter there's a chance debris sitting on top of it will fall down into the fan housing. I've heard that you can slot a piece of paper or card underneath before withdrawing the filter which should block stuff from falling in.
Thank you, mine turned out to be a small brown leaf too!
Hello Tom
Out of interest, where was the leaf, and how did you extract it? I ask because on Sunday last, I too noticed a "leafy" noise coming from my LC's fan. I haven't had time to investigate but f you could provide some clues I'd be grateful.
I had a rattling noise when the fan was on. It turned out that a squirrel had stored some hazelnuts inside the fan housing. I put a wire mesh over the air inlet after removing the nuts. It took hours to get at the heater matrix behind the dash.
