I finally managed to check out my sun roof drains.i managed to push trimmer wire down the front ones went down quite a long way.the rear ones I could not find as they are hidden..now tried to close the sun roof.that was ok went later to try again sun roof won't open 😞 now decided to give up and seal it up completely I keep getting a dashboard warning moon roof open it seems completely closed,so some sealent will be purchased soon..
Any suggestions thanks John
The rear drains come out each side of the rear corners . You can find then under the tray in the luggage compartment.  Mine were kinked there so I cut the flexible tube and spliced in a length of 15mm copper pipe which has kept it free of problems ever since.
