Will IS200 shafts fit the IS250?
Currently halfway through swapping out my diff with an IS200 diff and everything has gone to plan except the IS250 shafts won't fit in to the IS200 diff. They're too big.
Can i buy a set of IS200 shafts? Will they fit the hub? Anything i can do within the diff to make them fit? I'm really struggling here. 4.5 hours in and i'm starting to get frustrated over a job that's meant to have taken half this time.
I've just had a look around and i can get the IS200 inner CV joint as pictured below. Does anyone know if these will mount to my IS250 driveshafts? I currently have the halfshafts on the IS200 diff (The spline with 4 bolts) so need a way to fit them to my driveshafts.
Lexus IS200 MK1 inner CV Joint Driveshaft - Picture 1 of 3
  • 1 month later...
  • 1 month later...
On 9/5/2023 at 4:28 PM, MERC1 said:
Did you have any luck doing this swap hoping to do the same
Not yet. The diff is still sitting in my hallway. I'm going to get an IS200 driveshaft and see if they fit in the IS250 hubs. If anyone near Worcester has one laying around i could borrow for a few hours that would be great.
EDIT: The only info i can find is both the IS250 and IS200 have a 32mm nut size for the rears. So i assume the driveshafts from an IS200 will fit the IS250 allowing the IS200 diff/carrier to be bolted directly in place, swap the shafts and everything is dandy.
