Engine management lights linked to ABS plus TPMS
My 20006 model GS 300 Engine management lights keep appearing, then disappearing again after the system appears to 'dry out' maybe hours or days later.
I have now been told that maybe this is caused by a dodgy 80 Amp fuse. My mechanic also tells me that maybe hitting my ABS pump with a hammer can sometimes dislodge rust particles and that his diagnostics cannot tell the difference between a dodgy ABS sensor at the bearing end.
I have already purchased a new nearside wheel bearing and sensor and had it fitted at a cost of £500
 and all was fine for about 125 miles. He now tells me that maybe it is the master sender, or even a replacement ABS Unit is needed.
Also, my inside the tyre replacement TPMS wheel units refuse to re-set via the button beneath-dashboard as the mechanic's  £2.500 computer has failed to perform a permanent fix and I'm pretty much at the end of my tether now.
Is there anyone out there with a reliable answer, please other than scrapping my lovely car. with only 67,000 miles on the clock.
