Notchy Gear Change
fuzzyfelt
:lol:
Think it's the Bud :sick:
And is it me or does the short shifter reduce the clunking? Or is it just more likely I've got used to the box and know how to change gear to reduce / eliminate this?
Anyone here changed their gearbox oil with MT90?
Was there any noticible change, how hard to do etc?
Also, any tricks to refilling - Colin, when you say squeeze the new oil in I assume you have to 'pump' it uphill to get it in?
I know to check that the fill bolt can be undone before removing the drain!
Any advice appreciated.
I've used a garden pressure sprayer before to get the oil into a gearbox.
The filler is also the level plug so you fill it up until it runs out (make sure the car is on level ground first)
  • 1 year later...
