Is200 Tyres
PeteSE
The Bridgstone tyres on my IS200se need replacing due to premature wear on the inside edge/camber of both front tyres, rest of tyre still has 4mm tread left. The tyres have only done 10,000 miles & not driven hard or fast (honest).
Lexus say that this is normal due to the negative camber setup.
Any suggestions on which tyres give all round performance & will last longer than the 10,000 miles of my current Bridgstones.
If your wheel alignment is out it doesn't matter what brand of tyres you use. Some people have got 30k+ miles from the standard ones.
Get a full wheel alignment done and if they say the camber is within spec get it moved towards the +ve end of the allowable range.
