Airbag Dash Light?
imd7866
can anyone tell me how to turn off the airbag light, ive tried the ecu trick by disconnecting the Battery but no luck, ive installed the airbag but still no luck.
no electrician wants to touch my car becuase its an import and so does the dealership want to stay away from it.
any help would be appreciated.
I would check connection on the back and the bulb.. If you have to have it tested its hardly going to make any odds if u change the bulb... could well be a fault with your airbag if the steering wheels been removed at any point..
hi, what has happened is that the passenger side seat airbag has gone off and i dont want to replace it for the sva, so ive disconnected the entire seat but the light still stays on, so i dont know what to do,
do you know anyone or any way to take it off, its needs to light up and go off for it to pass the sva.
