Altezza Wheel Alignment Specs
ibanez
anyone got the alignment specs for the Altezza, will it be the same as the IS 200?
also, anyone know where I can get an owner's manual (in english) for the Altezza?
thanks.
eBay do the manuals (owners handbook with service intervals , how to change the washer liquid', 'jack up points' that sort of thing) Not like a haynes tho!
wheel alignment - should be same as is however have a search for wheels-in-motion or Dr Bones as he is the alignment guru! He can tailor alingment to driving styles.
oli
thanks.
more or less the same as the IS200, here are the specs anyway.
REAR
Thrust angle 0 +- 12'
Total toe 15' positive
Partial toe 7'
Camber 38' negative +- 30'
FRONT
Total toe 6' positive +- 12'
Partial 3' positive
Camber 35' negative + 25' - 35'
Castor 5 degrees 46' positive +-30'
Kpi 8 degrees 54' +- 30'
Toot 5% of the total lock angle
add any mods to the cars suspension then the set-up will need to be manufactured
