Ls 400 Door Handle
Ian Lord
Hi I am a new member with
1990 LS400, had it for 3 years and love it mileage now 152,200. recently had new cam belt, pullies, tensioners fitted, and she runs like a dream.
Drivers door handle (OUTSIDE) has recently started to stick OPEN, if I give it a gentle nudge it closes, and lock works normally.
Has any one encountered similar problem, and how did you fix it? I am concerned interior light may operate if not resoved as lifting handle activates interior light.
Would appreciate some help/ideas.
regards
IAN
The fittings on the handle break,so the handle part does not go back in cleanly.
If you take the door trim off you can see that the casing cracks,my moneys on the left side of the handle broken.I used a arodite glue which you mix with a hardener,that held the casing solid...or the other options are a secondhand handle or new one :crybaby:
