Key Codes
bribarb
I have a 91 soarer v8 and have lost the only key that came with it.
It is not a chipped version.
I have removed the lock from under the ignition on the assumption that it is the same as the ignition. the code stamped on it is 8072.
I am told that this is not a valid code and I would have to take a door lock out and read the key code off it.
Any body know a simple way of getting the key code?
