Help Desperate To Change Plugs
glad i could be of help, finally :)
i find them pages on there of some use
Steve
One thing to watch when you take the throttle body off it that on the refit all the little vacuum pipes don't get crushed as it make s the engine do worrying things. Its more apparant if you have a front brace on as they get very close to the top of the throttle body. Other than that its more awkward than difficult to remove it especially the bolts at the right of the throttle body onto the manifold, the ones at the bottom are a pain
