Speedo Conversion
dangerous brain
Well I know which one its not. Its not the same one as the supra is as I just tried that. I got the delimiter working as the needle went all the way off the clock and got stuck on max travel. The FCD works as well as its boosting like a nutter. I have come across one problem though. Since I disconnected the ECU the car won't idle properly. It idles way too low and cuts out which is a real PITA.
