Car Not Boosting As It Should
That kick from the s/c isnt there anymore. :o
What pipe work should i be checking?
I have just changed the Battery again (duff Battery from shop!!) could that be something to do with it, ecu?
take it for a run again and see. :tomato:
Come to think about it, it was boosting fine until the Battery change this afternoon.
What do i do to get the ecu values back or will it self learn after a few runs?
I have just changed the battery again (duff battery from shop!!) could that be something to do with it, ecu?
Come to think about it, it was boosting fine until the battery change this afternoon.
After the ECU has been reset it should learn your driving style within about 5-10 mins. At least thats what I was told a while back.
Wouldn't have thought it would have affected the supercharger tho as the only electronical thing on it is the blackbox, possibly worth checking all the pipework and the throttle cable just to be safe.
After the ECU has been reset it should learn your driving style within about 5-10 mins. At least thats what I was otld a while back. Wouldn't have thought it would have affected the supercharger tho as the only electronical thing on it is the blackbox, possibly worth checking all the pipework and the throttle cable just to be safe.
As Lee says, check all your clamps on the pipe work :D lots have had the same problems after just having s/c fitted.
Rsarin:Nah i dont think so. The ecu should recognise the fuel upgrade after a few fill ups. Obviously with my Battery dying it had to re-learn the settings hence why it started running like a bag of spanners whilst it recalibrated itself.
Have you looked into the turbo conversion etc?
What are your thoughts?
