Lexus Ls400 Interior Air Vents
Need to remove the air vent on the drivers side. can anybody Help!!
Syd,
Whilst replacing the climate control LCD's I have removed a couple of dozen center vents and cannot believe that the drivers side vents are totally dissimilar.
To remove the center ones direct the air flow fully downwards, then with finger tips on the revealed ledge wriggle the entire unit back and forth side to side etc, the unit is held in with spring clips only, no screws at all, once the clips are past there holding point the unit will slide out, I cannot guarantee that the side ones are the same, but it would make sense.
Regards,
Chris Vince
Syd,
Regards,
Chris Vince
I Hade no problem removing center vent, but the side vent is a bit stubborn, DON'T want to break it.
Help Help
Syd
