Fault Code
Rsarin
picked up 3 fault codes when the RAC blokey plugged his diagnostic tool in,two of them ive found but i cant find this one,even on his laptop just the code came up,no description. P1315
cheers lee,ill ask lexus what it is,do u reckon they will tell me over the phone?P0135-circuit malfunction,heated oxygen sensor.is that same thing?
P0135 is the heated oxygen sensor in bank 1.
Not sure mate, might be worth sending Chris a PM, or Gecco:8
cheers Lee.P1315 is for the igniter indicator not working according to Lexus,they say its about £150 to sort out.
I'm sure Mark will fix it for you when you pop down.
I would not worry or take your car to Lexus until he's looked at it.
I dont class myself as an expert but would say the factory ECU is getting confused from the signals the HKS unit is sending back.
Would wager that if you take it to lexus with what you've had done there will be a lot of head scratching and not a lot of problem solving.
