2nd Visit To Dr Bones
ok you fixed that strap across my rear end after lubricating the spongy bits and tightning my nuts :o
honor ......i lost that ages ago :D
ok tony installed a panhard rod !!
who here knows what one is ?
not many i fear
Isnt a Panhard Rod to reduce axle wind up, didnt know it was a problem on the IS
Sounds like a Bones wind up
Infinity.............
i will let tony explain in detail
isnt a problem on the IS .....they dont have them :whistling:
this was fitted to the starlet :D
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
