Hi All
It's time to service GS 300 (MKII) and since I didn't change the fuel filter the last time (hoping it should be ok :whistling: ) I was wondering would anyone know where it is on the MKII.
I also had a peep at the air filter, although I changed it 15k miles ago, it's filthy so I'd better change that too
I was also thinking of adding a fuel injector/valve cleaner, are they any good? can anyone recommend a decent one?? or are they a waste of time
Any advice greatly appreciated Cheers :D
P.S What do people think of oil flush additives, should I use one even though the oil is renewed every 10k??
Hi All
Don't know where it is (follow the fuel lines), but I'd check for corroded pipes before buying a replacement. If the pipes and/or joints are corroded, leave it alone.
