Has Anyone Ever Had Their Tv Working In There Altezza
mAltezza
Cool i have another look at my wiring and try to figure that out. Are your speakers amplified with an external amp, located behind the glove box? Not all models have them. This could explain the difference between wiring schemes.
no m8 mine dont have amp its 1 without
but i dont think that should matter the sound wire from tv tuner should be same
the only differnce in my opinion is my tv tuner has a converter betwee wiring but some one has converted yours coz on the second wirin block which is different mine only has 4 wires before converter
Ok so how does your dvd player get its power?
Are the cables from the dvd player RCA output?
So i should get an RCA lead going from the dvd player, chop off the plugs at one end and wire them into the block that i disconnected the tv tuner from, they way you described above.
my dvd player gets its power from back of the standard head unit.
yes you can use rca cable chop the ends on 1 side and wire it accordig to my discription but wiring block needs to be re connected to tv tuner if not it wont work
but if your going to wire dvd player in glove box like me make sure the rca cable is long enough
advice: if you follow oem wiring back through the boot you will find the is openin for wiring so no need to make any new holes
